RE: landing technique
Try this, always use the same landing approach,the same speed,chop the throttle at the same time. Once this is pre-set in your mind you can concentrate on the landing, and remember to jockey the throttle to land perfect every time. I've had people tell me all my landings look the same no matter what I fly. I did this as a newbie and never deleted from it. I land on the field at the same spot almost every time and I stand at the same place. Most of the above I don't try to do they just happen because of lots of flight time and thats what you need. Good luck!
