ORIGINAL: wzak29
Forward and aft ¼” stabilizer joined with G.P. Pro wood glue (aliphatic resin) the manual says to use CA but I will be using this glue anywhere that requires sanding it sands much better, The elevators will be joined next using a joiner wire.
I am using Elmer's Glue-All for the majority of the build, but am also using medium and thin CA where necessary. Instead of spending extra for different speed epoxies I will be using 30-minute where required.
