RCU Forums - View Single Post - 1/5 scale cub problem
Old 05-14-2009 | 02:57 PM
Big-Mo
Default RE: 1/5 scale cub problem
Thanks for all the tips and suggestions guys. I'm used to flying mid and bottom wing planes. ive been flying for 11+ years and have never had a plane do anything like it this bad. ( I know been flying for 11 years and don't know how to trim a plane) Believe it or not i did y training with a Walt mocha novi, was the sweetest plane i ever had. (buddy) spun it into the ground when he ripped the vertical stab lose.. sigh oh well.
There is no way for me to adjust the wing incidence i believe as it is a two aluminum tube wing support(plug in wing in a arf), I will check the engine thrust tonight to see what is it . and adjust as directed. the plans show nothing as it was a arf. almost like the hangar9 15 scale cub only a little bigger.
I don't think i mentioned this part but it will take off in about 30 feet IF the elevator is at neutral. I have about all the elevator trim i can put into it with the trim switch.
