RE: I need help with a lateral balance problem.
Thanks for the replies. I will explain it better. If I set all my control surfaces to neutral and take off I will need to trim my ailerons to the right quite a bit to get level flight. That's the heavy side of the plane. I'm scared to add weight to the light side to balance it as I think it will be worse. Thanks for your replies.
