RE: Your BUGGY and SETUP
BUGGY : Team Associated RC8 FT
THR SERVO : Associated DS1015
STR SERVO : Associated DS1015
MOTOR : O.S. V-spec
PIPE : JP-3
RADIO : DX3R
CLUTCH : Stock AE clutch with Impulse-RC Hard (2024) Aluminum shoes and 1.0mm springs
CB : Stock AE 16T
WHEELS : Proline or AE, White
TIRES: Holeshot M3, Crimefighter M2, Switch 2.0 Clay
DIFFS F/C/R : 5K, 5K, 5K
BARS F/R: Silver Front/Gold Rear
SPRINGS F/R: Front- OFNA 16mm Blue/Rear- OFNA 16mm White
SHOCKS F/R : 35wt oil F+R, Holes: 1.2x6 Front/1.4x6 Rear (AE big bores F+R)
DROOP F/R : No droop, 2mm internal limiting front/4mm internal limiting Rear, otherwise F+R shocks at stock lengths
RIDE HEIGHT : 29mm F+R (varies)
CAMBER F/R : -2 F+R
WHEELBASE: Medium
CASTER: 16
TOE F/R: 1 Out Front/3 In Rear
WING: Back and Low, AE White
ADD INFO MODS ECT: setup based on Cavalieri 2008 The Dirt Nitro Challenge setup, big bores, updated steering mod, AE Aluminum Top Plate,
AE updated fuel tank, Jconcepts Illuzion Body, Powersave airfilter elements and UndergroundRC prefilter cover, Impulse-RC clutch shoes
RTR chassis braces (still flexes, won't break like FT stock) AVID and Boca Bearings (steel)
