H9 Funtana. PICTURES OF ARF IN BOX, COMPLETED, INFLIGHT, IN THIS THREAD!
I have snap spoilerons set up, I hope to try them next time out.
It looks interesting. Because they are setup to only come on when the elevator stick is near max travel.
You can still fly with the mix switched on and it will not affect the low rate because the travel never reaches that point.
It doesn't affect the high rate either until you pull or push the stick all the way.
I have them set to go 100% but don't know yet if that will be good or bad.
