RE: different blend
I am not familiar with that engine, I assume it is in a car. Most engine conversions come from Davis Diesel Development. I would suggest checking his site and see if your engine is listed. He is in the process of moving from CT to TN so he may be slow at responding right now.
No on the fuel mix you suggested. Model diesel fuel is a mix of ether, kerosene, and castor oil, plus an ignition improver such as amyl nitrate. I would suggest you use commercial fuel until you get used to running and adjusting your engine. Davis also sells fuel. Model diesel (or compression ignition) engines have an adjustment for compression that you need to learn to optimize. You don't need questionable fuel to add to the confusion.
Good luck with your conversion. Another thread has new contact information for Mr. Davis. If you can't find what you want online, contact him. He is very helpful.
George
