RCU Forums - View Single Post - The Wings Maker Ultimate 40
Old 05-16-2009 | 03:50 PM
Greg Covey's Avatar
Greg Covey
Default RE: The Wings Maker Ultimate 40
The other ends of the elevator and rudder control rods attach to standard size digital servos. The supplied keepers create a simple yet secure connection to the servo arm. The unused position was for the glow engine throttle servo.
A hardwood platform was then glued in place with epoxy. It was supported on the bottom by short blocks glued to the fuselage top. I then covered the platform with a Velcro strip which was securely CA'ed in place. My 6-cell EON28 3350mAh pack fit perfectly as it was supported on all sides. A small piece of flooring foam will be wedged in between the LiPo pack and the hardwood slat I used to reinforce the former.
ID:	1199524   Click image for larger version
