RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT
I'm building a ducted fan model and need to extend the leads (12-14 inches) from the 45 amp ESC (Electrifly) to the Ammo in-runner motor driving the fan. (24-45-3790kV) constant current = 25A, maximum surge current = 50A. At 11.1V maximim constant watts = 278. The best wire I can find in the hobby store catalogs is 12ga silicone manufactured in this case by Deans. I use Deans connectors so this seems to be the right wire but I don't find any data showing current ratings. Have I got the right wire for this application? Is there a source somewhere to size and purchase the proper lead wire?Ducted fans will typically physically separate the ESC from the motor and will require longer leads. Thanks for your help!
