RE: ESC location
I've had both in the duct and outside the duct. I'm beginning to wonder if hanging the esc in the duct may actually be detrimental.</p>
Two things I'm seeing on a duct mount. One the esc could be screwing with airflow, causing a turbulence issue. And two the esc is exposed to high speed airflow, you ingest something and it hits the esc and could cause some problems. Swallow a June bug/ beetle or other hard shelled insect and I could see an impeller exploding and blowing back into the esc. Fan is cheap to replace compared to an esc. </p>
My F-20 exhaust tube looked like an insect debris field after only a couple of flights over a meadow. Blades had all kinds of remnants on them.</p>
And I thought only gassers needed clean up after flying.</p>
