RE: Ziroli DC-3/C 47
Hi Chris</p>
thanks for the reply </p>
thats a relief the former F8 was warped considerably , its reasonable now as this one i think needs to be straight as this former is where the back of the wing center section will sit .</p>
are you going to use a fiberglass nose section or built up?</p>
i have a fiberglass nose section and was woundering if solartex would surfice using as little heat as possible perhaps </p>
apologies for bombarding you with all these questions </p>
but as you know there is no instruction book for this plane</p>
which is a pitty, so any help is appreciated</p>
thanks </p>
</p>
Paul</p>
</p>
