RE: Modifying the wing incidence
There is nothing wrong with adjusting the wing incidence if you are not pleased with the flight characteristics of the model. Just shim up the back of the wing with a popcicle stick and see if you like the way it flies better. Increase the number of popcicle sticks one at a time until it flies the way you want it to. Its not going to hurt anything to try one popcicle stick at a time.</p>
I just adjusted the wing incidence on a Thunder Tiger Trainer by doing this with a piece of 1/8" lite ply I like the way the plane flies better... it no longer climbs like crazy with throttle increases.</p>
