RCU Forums - View Single Post - The Wings Maker Ultimate 40
Old 05-18-2009 | 06:30 PM
Greg Covey's Avatar
Greg Covey
Default RE: The Wings Maker Ultimate 40
The canopy comes with pre-drilled holes and a roll of double-sided tape for east installation. The rubber eyelets keep the canopy plastic from cracking and the double-sided tape provides a good seal to prevent wind from entering along the front and sides.
The lower wing aligned itself with the pre-installed wooden dowel on the leading edge and the pre-drilled hole in the hardwood plate on the trailing edge. The seam was perfect and the wing was held securely in place with a single M4x25 screw into a pre-installed T-nut in the fuselage.
Note that an air exit opening was cut into the cowl bottom with my Dremel tool.
ID:	1201264   Click image for larger version
ID:	1201265   Click image for larger version
