RCU Forums - View Single Post - Airtronics RDS8000 Lipo
Old 05-19-2009 | 04:58 PM
carrellh's Avatar
carrellh
Default RE: Airtronics RDS8000 Lipo
ORIGINAL: norstaroption
What type of connector does the NICAD battery for the RDS8000? I would like to charge the battery using my Hyperion charger but I couldn't any adapter for it? The battery on mine only last 1.5 hr and 12 hours to charge with provided charger.
The connector on the battery pack is the Airtronics Z connector. You can make a connector for your charger using a servo extension. The Airtronics Z connector is almost identical to the Hitec S and JR connectors.
<< edit to add >> If you want to make something to connect your charger through the plug on the side of the transmitter, this is available for $3.00
http://www.hobbypeople.net/gallery/477037.asp
