RE: New Supertigre G90 with scratches on the piston.
No, it's not piston ported...so you wouldn't gain any performance there. (except for marginally lightening the piston )</p>
</p>
The ST .90 is more of a torquer, not really a revver...but some "softening" of the sharp edges in the mixture's flow path might prove beneficial?
You might find a burr or something along the edge(s ) of the ports that caused the scratches, so dis-assembly might be worth while.</p>
Once broken-in and the carb is adjusted properly, they are (or can be ) nice running engines.
</p>
