RE: TT .46 Pro Break In Compression
The two step is normal. It's the piston crossing over Top Dead center. . . the con rod snaps from one side to the other at TDC. I'm not sure about the lack of pinch w/o the glow plug. I'd have to check one of mine.</p>
My TTT PRO 46 was acquired used and has no gasket. It's not a problem, but does lead to higher compression.</p>
Jack</p>
