RE: BME 58 Extreme
Guys....if your motor is running lean....check the gasket between the carb and the reed cage. Mine came loose on the first couple runs and it steadily got worse and worse before i figured it out. Tom sent me the new reeds that the first run motors needed , and it fixed the problem as well. I still only have about 6 tanks through mine , but should get to fly it again this coming weekend quite a bit.
