RCU Forums - View Single Post - New Supertigre G90 with scratches on the piston.
Old 05-20-2009 | 06:29 AM
Trinut
My Feedback: (26)
Default RE: New Supertigre G90 with scratches on the piston.
As far as reed block, rotary valve and piston port goes, in this engine it is the hole in the crankshaft that periodically opens and closes under the carb that handles the job of allowing air/fuel in the crankcase, then sealing it off on the downstroke to allow the backside piston pressure to pump it into the cylinder through the ports.
