RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 05-20-2009 | 10:17 AM
  #1139
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
HI Chris,
Here are a few pics of my install.
Iused 6-32 threaded steel rod and dubro aileron horns. bore the hole as close as you can so the hole in the horn is as close as you can get. We are using 1/2 dowel as a hard point. If your all concerned about getting the hole over thehingeline you can always bend the rod
Another tip is to drill and install the exit guilds after your glass - you won't get a bump orbulge. You will also get a cleaner exit. I've been using DEPS scraps for the exit tubes.
you can also see my retro fitted deps in thesepictures.
<br type="_moz" />
ID:	1202433   Click image for larger version
