RCU Forums - View Single Post - BOT ARF is here!
Old 06-19-2003 | 03:15 PM
ec121
Default BOT ARF is here!
Received my BOT arf today. Really nice! Already has some weight in the nose. All visible wood is laser cut. Even comes with a bag of shot to add more weight if needed. There is no bellcrank in the tail. They want you to put a servo there. However, the hatch is already cut out so it would be easy to install a bellcrank and put the servo in the nose. Otherwise the servo needs a 30" extension. Tip joiners are ply/aluminum laminate with alignment pin near the trailing edge. Tinted canopy with wooden base. Can't weight to fly it! The book says to use a standard histart since it is a lightweight.
