RCU Forums - View Single Post - Ziroli DC-3/C 47
Old 05-20-2009 | 08:07 PM
gblas777
My Feedback: (13)
Default RE: Ziroli DC-3/C 47
heres a little more progress....the outer wing panels are a pretty much a straight fwd build......extra care was taken when glueing the wing tubes in to get them absolutely straight and parallel......the center section shows where the fuel tanks and retract bottle will be mounted. eveything should fit inside the wing...they are 16oz tanks....one for each engine and a robart large air bottle.....enough room for all to fit inside the ribs and not interfear with anything....and last the 2 firewalls drilled for the g-38s and the relief holes cut for the spring starters..the engine is wide enough for the fuel line and throttle pushrod to run outside the firewall so it doesnt get in the way of the retracts which are mounted right behind the engines..more to come soon
gene
ID:	1202694   Click image for larger version
ID:	1202695   Click image for larger version
ID:	1202696   Click image for larger version
