if you took the backplate off the engine and the head off at the same time.the screws are different (dont ask how i know
) and will feel stripped when put into the head</p>
but if thats not the problem then run to ace hardware or similer and get some bolts (m3 most likely)
if the "nut" is stripped good luck.try locktite maybe ?</p>
