RCU Forums - View Single Post - BOT ARF is here!
Old 06-27-2003 | 09:46 PM
Miami Mike
Default BOT ARF is here!
Originally posted by TomM
Just came in today.
It's so easy to install a bellcrank instead of the micro servo.
The pushrod outer tube is already there! Just pull it out of 2 formers (it's held in with silicone glue) and re-install it into the lower holes- already drilled in the formers.
Pics to come.
I'll be watching for those pics! A little bit of weight saving in the tail balances with a much bigger weight saving in the nose.
What is that upper tube meant for anyway? The only thing I can figure is that you're supposed to run the elevator servos wires through it to your receiver.
I didn't like the all-white wing bottoms so I added some big dark spots. Here are some pics. (My server's down now but should be up soon.)
