RCU Forums - View Single Post - BOT ARF is here!
Old 06-27-2003 | 10:32 PM
TomM
Default BOT ARF is here!
That's what I figured- for the wires- but you'd have to solder the connector on after you ran the wires through it.
Ran into a bug. In order to mount 2 standard servos side by side, I have to widen (Dremel) the cut-out in the plywood servo tray. Plus, being a round fuselage, the servos have to be 1/4" to 3/8" higher to have some bottom clearance. Then I'll either have to drill higher holes in the former, or just put a jog in the steel pushrods.
Nice spots- I'll have to try that or a broad stripe. I like you templates!
