RCU Forums - View Single Post - Best material to use on top of your work table
Old 05-20-2009 | 09:25 PM
tassiemark
Default RE: Best material to use on top of your work table
A sheet of Homasote on a used hollow door has been my choice to build on,inspected a lot of doors tho with a level before I found one perfectly flat,beware they do vary quite a lot.Pinning is never a problem and they don't work loose or pull up easily unless you want to remove them.</p>
