ORIGINAL: HKruisman
Hi JetJoe fans
During accelleration the temp rises to 610 but at 160k it settels quickly at 554. YES, 554 degrees egt at 160.000 rpm
Very nice........ very very nice.....
The 2 piece cone looks very nice and runs great but has les power then the 1 piece. I don't know if it has less thrust then the cutdown 1 piece but i will findout when i fyl the plane
Mine used to run no more than about 500deg with the two piece tailcone but thrust was well down than what it should be.
Once I changed it to a single piece tailcone the temps now at 160K run around 590-610deg and the thrust has increased by 3lb
