RE: engine cleaner
hi been flying and repairing glo engines for 20 years started out using full syn glo fuel and found much more wear in the early days than when i switched to a castor -syn mixkeep in mind that castor oil breaks down from heat 100 PLUS degess over the syn oils-so you are protected when (not if ) you run you glo engine a bit lean on a particular day-there now doesn't that make you feel better-better to clean your plane than to cook your engine any day
