RCU Forums - View Single Post - WHY? Balance low wing airplanes inverted?
Old 06-19-2003 | 06:15 PM
FLYBOY's Avatar
FLYBOY
Default WHY? Balance low wing airplanes inverted?
It just appears to move when it is right side up. As intruder said, if the tail is just a bit high or low when you try to ballance it that way, it will tend to rotate. Thats why it appears to move. The inverted ballance point is more accurate, and is the one to use.
