RCU Forums - View Single Post - 2.4 antenna question
Old 05-22-2009 | 02:16 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: 2.4 antenna question
A lot depends on how you hold your Tx.
A 2.4 antenna broadcasts from the side, not the tip. So if you hold your Tx down, and the antenna is pointing up, that's bad. But if you hold your Tx up it's ok
I keep mine pointing to the right side, that way it doesn't matter how I hold the Tx
