RCU Forums - View Single Post - old skybolt
Thread: old skybolt
Old 05-23-2009 | 08:09 AM
aerowoof
Default RE: old skybolt
the large st are not high rpm engines they swing large props at lower rpm like the gas engine you are refering too. you need to think prop size for speed and thrust small prop high pitch is speed large prop low pitch is thrust.your diameter will be limited by ground clearence so start with the diameter that gives you good ground clearence and work displacement from there
