RE: JR PC data transfer system
<span style="font-size: small"><span style="font-family: Courier New">Zeeb,
I had the same issues as you a couple of time and was able to start it again and it would work. However,mine will not work at all unless I disable the driver verification first.
The tech person from Horizon I have been dealing with via e-mail, called me yesterday and hooked into my pc to see what was going on and to create the errors. We were on the phone for over2 hours and he tried manythings and we still got the same results. He says he has not hadthese problems since using this install procedure but he agrees that more needs to be done. He is going to do some more work on it andwe are suppose to hook up again next week and make another goof it.
One thing he told me was that he was testing with the X9303, the 2.4ghz transmitter.Once installed he has had no issues at all.I have the XP9303 and he hadnot tested with that. Ican't remember if he saidhe did anything with the 10X or 12X but I don't think so.
I doubt it is the transmitter. To me it looks like when you press start and the program tries to configure the usb device, windows is checking to see if the driver is verified or not. If it isn't, it isn't working, period. My understanding the verification process is suppose to prevent hacking your system which to me makes sense why it won't work as well as additional revenue to Microsoft for people to validate their drivers.
If you are interested in trying theinstructions anddriver he sent me, send me a PMwith your e-mail address and I will send itto you.He sent me a driver but it is the same one we already have.For now Ijust disable thedriver enforcment when I want to sendor receive with the transmitter. You can use the program to change your settingsonce the fileis there or you can create your own.
</span></span>
