Glow fuel; whether it be Cool Power, or Omega, will attract moisture from the air. All motors have some fuel residue left behind even when run dry of fuel. That is why the bearings rust out, minutely at first, but will get worse as the motor is used.
Fuel that contains a sufficient amount of castor oil, will have enough of it thoroughly coating the bearing races and balls; thus preventing their contact with the moisture accumulated by the hygroscopic methanol.
Myself and two friends have had this problem with the OS1.20AX, OS1.40RX and myself with OS1.60FX. Changing to stainless, or ceramic bearings cured the erratic tuning problem.
This is purely circumstantial... Stainless steel bearings do offer greater resistance to corrosion and silicon-nitride balls cannot rust...
