RCU Forums - View Single Post - Sond and smoke?
Old 05-24-2009 | 12:08 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: Sond and smoke?
ORIGINAL: thomasjohnmurphy
with the airsoft, does the tank recoil as when you use the IR?
TJM,
<div style="margin: 0in 0in 0pt"></div><span style="font-size: 9pt">Let me see if I can clear this up! When you buyoneof thenewer tanks ( Jagpanhter, StugIII, or KV-1 on....)from RCTankWars.com, Mato Toys, or other,,,and it comes with the recoiling barrel, it is not does not shoot BB's and it has the wiring for and is IRcapable for their non Tamiya compatible IRsystem! IT recoils the barrel and it recoil rocks the tank, like the old tanks! If you buy one of these new tanks Airsoft version,, it responds and acts exactly like the old version of tank,, ie RX-13. 14 with a little better sound out put and in theory a little more robust drive fets! So the tank will recoil,, but of course not the barrel when you use the airsoft,, if you add on the HL IR to the Airsoft which could be done,,, it does not affect the tank Recoil unless you buy a DBC/DBU or DBCRC2 From RCTankWars, that removes the fake tank rocking!
The Blitz</span>
