RCU Forums - View Single Post - ???rookie questions???
Old 05-24-2009 | 02:43 PM
millertym2000
Default RE: ???rookie questions???
On take offs make sure you can keep it straight down the runway before lift off.you need to be able to control it on the ground beforetrying to take off. sounds like you need to tune the engine some more, sounds a little rich, Make sure everything is tight around the motor mount. the mount to the firewall and the engine to the mount. .
