RE: NJ One Design
Ifinished the covering today. Tomorrow I will mount the engine, servios and balance it. Imade some changes. I built the wing as a single unit and cut a hole through the fuse to mount it. Ihave servos for the rudder and elevator in the rear of the fuse. Also the throttle servo will be right behind the engine. I tried to keep it light. I will be very happy with 4 LBS. If it is a few ounces heavier I am sure the Magnum will handle it fine.
Maybe next weekend will be calm enough for a maiden flight. It sure is gusty today!
Frank
