RCU Forums - View Single Post - Ed Kazmirski's Taurus
Old 05-25-2009 | 04:15 AM
  #1599
Taurus Flyer's Avatar
Taurus Flyer
Default RE: Ed Kazmurski's Taurus
ORIGINAL: UStik
ORIGINAL: Taurus Flyer
<div style="margin: 0cm 0cm 10pt">UStik,</div><div style="margin: 0cm 0cm 10pt">I only did want to show you that it is possible to calculate dimensions when you have the right picture and know the methods. Result is that I did prove the Oldest Taurus on Earth really did exist but I do not see that in post 1576 of page 64.</div><div style="margin: 0cm 0cm 10pt">Your question?</div><div style="margin: 0cm 0cm 10pt">Do not use <span style="font-size: 10pt; line-height: 115%">&ldquo;measurements made off small photographs, sometimes taken at undetermined angles&rdquo; see post 146 page 6 of my thread.</span></div><span style="font-size: 11pt; line-height: 115%">Cees</span>
As usual, a miss is as good as a mile. Cees, you are as helpful as a charlatan.
<font size="2">
Ustik,</p></font>
For redesign I use several methods combined with own design exell sheet calculations and graphics, drawing programs and "solver" calculations on a HP programmable calculator etc.</p>
Planimetric methodsand goniometric calculations arethe basic behind the solutions.</p>
To give you an example of the start of one of my methods, I show you a "planimetrical" solution for your question when you give me the right picture. Remember there are only 1 % of pictures like these, direct useable!
Accuracy:Make this drawing the best you can!!!!
So, no Cheap Skate no Charlatan, but modeler who does also build scale models.
Oh, if nobody could have tell you the stab of the Simla was 34,0 inch I could have tell you that.</p>
Cees</p>
Edit: I see there is a wrong presentation in the picture, it must be TE wing LE stab is 1 3/4 chord but it;s only an example.
