RE: cheater?
Sounds like someone put the Y harness in the box by mistake. What you should have is a 6 or 12 inch extension to go from the receiver to the aileron servo. Leave it as a 4 channel plane. Tieing the ailerons to the rudder will cause you trouble that you won't be able to recover from.
