RCU Forums - View Single Post - Tip: Easy FIX for the weak operating Tamiya elevation unit
Old 05-25-2009 | 03:29 PM
Panther F's Avatar
Panther F
Default RE: Tip: Easy FIX for the weak operating Tamiya elevation unit
Pulling the affected gear out is a breeze. Just remove the brass spacer sleeve outfirst BEFORE pulling the smallgear apart from the larger gear. A 2 part epoxy is much more cleanerway ofgluing than CA. Sand both sides, apply the epoxy to both gears and press the gear back in. Once it's set, re-install the spacer from the small gear side and then place back into the elevation unit.
Easy peasy, lemon squeezie.
