pressure with perry pump
Hobbsy,
Perry's instruction sheet says not to install the muffler pressure. Since it works fine with the pressure and my pump failed early I am assuming that using muffler pressure does damage. Yes you can run fuel through it, the instructions warn against that also. Since there is definately a restriction that gets worse the harder you pump, I am assuming that the fuel flow is restricted to .25 lbs even if pumped through externally.
