Flatout - I have two of those Baja Champs. Both have been great bashers. When the photo was taken that car had a stock silver can in it. It works pretty well stock but the one big problem with that chassis is the limited gearing options. If I remember correctly you can only use a 15 thru 18 tooth pinion. That car currently has an old titan in it geared with the largest pinion i could get in there.
The second Baja Champ has a Tamiya sport motor and is setup to run on road.
Here are a couple of more pics. Please keep in mind that some of these pics are old and the setups have changed.
New build. All stock Fire Dragon.
The Twins. A pair of Baja Champs. Black car has a Titan in it. White car has an older Tamiya sport motor.
Another Twins Pic. These are the TA02 chassis from the early 90's. The F150 is my bashers. The Pre-runner is a shelf queen. It's all stock and has never run other than to set the servo.
