RCU Forums - View Single Post - os 160 FX Piston Ring Replacement
Old 05-26-2009 | 10:15 AM
Bax
Default RE: os 160 FX Piston Ring Replacement
Use the head of a large carriage bolt to act as a pry bar to get the lower end of the rod off of the crank.  You do have to make sure that the rod will slide as far aft as possible on the piston pin.
