RCU Forums - View Single Post - Accurized M4A3 (75) W
Old 05-26-2009 | 11:58 AM
  #73
streetsquid's Avatar
streetsquid
Default RE: Accurized M4A3 (75) W
Whitewolf,
Glad to hear you think the drawings will work.
I don't know maybe I just got lucky but when I built mine it all just fell together. I only had to remake one part ( I had cut one of the louvers a tad short and so I cut new one a bit longer) and I didn't use any drawings. I took some basic dimensions off of the resin piece and started cutting out and gluing parts. I did the drawings off of my built up deflector after it was done so you'll have to let me know how well the drawings work if you use them to build your own.
Having the resin piece here was a HUGE advanatge, but I'm hoping that between the pictures and drawings I posted it should make it pretty clear. I think the build photos will help clarify any confusion or questions the that might arise from the drawings. It really is quite straight forward and was a lot less difficult than I thought it was going to be. By all means let me know if you have questions or if I can help in any way.
Regards,
Squid
