Factory for the HSN is 4 turns open. Turn the needle all the way closed (clockwise), but do not over tighten it. Then back it out (counter-clockwise) 4 turns. Factory for the LSN is flush with the end of the slide. The manual does not give a factory setting for the idle, but most engines are set to a 1mm opening looking in the carb. Check page 24 of the Rustler manual for factory settings, including a little drawing showing what "flush" means, and that section of the manual in general for tuning info. Here is a link to the manual if you do not have it handy.
http://www.traxxas.com/products/nitr...9nr_manual.pdf
Good luck.
Bryan
