get the lead out
Weight is the enemy. Remove the battery pack, place the plane on a CG machine at it's proper balance point. Set the battery on the fuse moving it aft until the plane balances. This is where you need to build your hatch. If the plane has a solid bottom cut out a hatch slightly larger than the battery. Do some covering work. Install some hold down tabs & you're good to go.
Joe
