RCU Forums - View Single Post - xyz cdi
Thread: xyz cdi
Old 05-26-2009 | 08:12 PM
michael wood's Avatar
michael wood
Default RE: xyz cdi
Well I got my xyz ignition today and I set it up using the instructions from ch, I had a problem with it sucking gas to the carb even with the choke closed I just keep on flipping and it would bearlystart to draw the fuel so igotout the starter and boy did it fire up quick. When I went toadjust the carb it quit.I figured I lost the ignition unit wrong the magnet can out guess I didnt have it glued in good. So I put another magnet in and jb welded it and ping it around the magnet I am using a 4.8 volt battery pack on it I will try tommrow to start it and adjust the carb michael
