RCU Forums - View Single Post - Which Monster Truck?
Old 05-27-2009 | 12:35 AM
Barber420
Default RE: Which Monster Truck?
ORIGINAL: Jarrett123
Sweet where is the cheapest place to pick 1 up? Also what are some good oil/ spring setups for bashing. I generally go pretty stiff for jumps and flat landings.Another one last thing before i close this. What should i do before running it?
How do i close this thread???
You'll have to look around online to find the cheapest place. I would start with ebay, amain hobbies, my atomic hobbies, and the RCU marketplace. If you have a coupon code Tower could be cheap too, but they're usually one of the more expensive online stores.
I was running one stock blue spring in each corner with 40wt oil inthe shockand one red spring in each corner with 50wt, and it did ALOTbetter than stock. However, I found some progressive rate springs(they range from 3lbs to over 7lbs when cycling) on ebay for really cheap so I put 4 of those on where Ipreviously had thestock blueones. So far it's been even better handling and hasn't lost any of it's jumping abilities. I broke an a-arm finally a few days ago though so it's been OC until I can go get a new one.
I keep my ride height set to a bones level stance too. This keeps it handling rough terrain like a champ and prevents it from wanting to roll as bad, but still gives you plenty of travel for jumps.
