RE: small gasser
Yeah, that's the one; the Big Stik 60. It's easy to bash it into a tail draggin' low winger. Fairly cheap too if you wait until Tower Hobbies has one of their 20 dollar off ads. If you get one, you might do what I did. I ordered the correct color red covering with the plane. I then used it to cover the black Iron Crosses and white areas on the bottom of the wing. It was too easy to confuse up from down while flying with the white areas and black crosses on both the top AND bottom of the wing.</p>
AV8TOR</p>
