RCU Forums - View Single Post - 12x antenna
Thread: 12x antenna
Old 05-27-2009 | 07:35 AM
GrayUK's Avatar
GrayUK
Default RE: 12x antenna
<div style="margin: 0cm 0cm 10pt">I disagree with this completely.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Pos 1 and 3 are sort of acceptable but who the hell flys like that?</div><div style="margin: 0cm 0cm 10pt">Pos 2 is the most common position, and to quote Horizon</div><div style="margin: 0cm 0cm 10pt">&ldquo; a cone of silence&rdquo; directly off the end if the TX.</div><div style="margin: 0cm 0cm 10pt">So why recommend a position with that &lsquo;cone&rsquo; pointing where you fly?</div><div style="margin: 0cm 0cm 10pt">If you check the JR site they recommend the aerial facing down at 45 deg.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Paul</div>
