RCU Forums - View Single Post - Help Programming Tamiya Tiger 1 DMD!
Old 05-27-2009 | 08:47 PM
Planedev
Default RE: Help Programming Tamiya Tiger 1 DMD!
Also a reminder, not all manufacturers have their channels set up the same, meaning channel 1 of futabe might be a different channel on another manufacturer, one you found out which channel is connected to which stick movement (via a servo lying ard) then you can start putting in the channels to the right places.</p>
From your post anyway, I think you just have to swap the throttle and steering channels on your receiver and all should be good.</p>
