Pull-Pull Elevator on DP Ultimate - am I missing something
I hate to disagree with you fellows; but all you are doing is adjusting the cable tension. You are not adjusting the throw at all. The only way you can adjust the throw is by moving your cable attachment in or out on the horn (closer or farther away from hinge line). Tell me were I am wrong.
